Old 12-29-2020, 10:32 AM   #16
JayG
On the slippery slope
JayG's Avatar
You also should factor in what track class you want to run in. If your going Spec, then its pretty cut and dried to what you can and can't do. If you are running in a prepared class you need to look at the rules for that class and what impact aero has on the classes.
For example, Aero will add "performance" points and that could move you into a higher class where you may not be as competitive
2004 996 Targa Tip
Instructor - San Diego region
