Thread: IMS center bolt
Old 12-29-2020, 09:52 AM   #4
Homeoboxter
Originally Posted by WhiteyII View Post
So a couple questions, the really crappy oil that comes out when the bearing is pulled is there because of the inner seal causing stagnation or in other words because the inner seal doesn’t allow the oil to flow thru the bearing? Does the Retrofit LN bearing have an inner seal or does it let the oil flow thru or rely on immersion and splash?
I appreciate you guys and your knowledge.........
The original bearing is sealed with grease filled inside. IMS is a tube with about a liter of air trapped inside, since both ends are closed. When the engine warms up, pressure rises within IMS, and after a while air will leak through the bearing`s seals, creating vacuum when the engine cools down and the pressure drops. Eventually this will cause the oil to seep into the IMS, and will fill it, since the entire shaft is submerged in oil. Since it does not circulate so well, and you can`t drain it when replacing engine oil, it will become darker and crappy than the rest of the oil in your engine. So, if you just remove the outer seal, the bearing will get sufficient lubrication from outside. Somewhat depending on the oil level in your crankcase, it will get direct oil from being submerged, from splash, plus oil mist.
As far as I know the retrofit has no seals.
Homeoboxter is online now   Reply With Quote
