So a couple questions, the really crappy oil that comes out when the bearing is pulled is there because of the inner seal causing stagnation or in other words because the inner seal doesn’t allow the oil to flow thru the bearing? Does the Retrofit LN bearing have an inner seal or does it let the oil flow thru or rely on immersion and splash?
I appreciate you guys and your knowledge.........
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
