Thread: Problem!
Old 12-28-2020, 09:30 PM   #12
pilot4fn
Originally Posted by evomind View Post
I jacked the car up today to take a look but all I could see is remnants from fluid. Drip marks on the header at the bottom about where it turns to the mid pipe. Could not determine the source.
Tomorrow Im going to start the car and let it heat up and try again. Hopefully Ill see it actually coming out somewhere.
I have a feeling without removing the underside plastic shielding I wont be able to see much.
Im very pressed for space and tools.
Other than red coolant blow back everywhere on the rear drivers side, everything looked really good.
lol
Open the engine top cover to see it it is the oil cooler or some other that leaks you can see from above. For this you do not need to start the engine - put a power on and open the roof to service position, then the engine cover can be opened up.
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
