Thread: Audi Swap
Old 12-28-2020, 03:28 AM   #18
beater986
Originally Posted by KenDFW View Post
Hi Radium King! I have the old audi axles in my garage along with the oem bolts.
Boxster 2.5/2.7 uses 8mm bolts (That's why I had to swap axles)
So the Boxster S uses 10x50mm bolts
The 1.8 A4 FWD axle bolts are 10x48mm 12mm triple square head bolts
So- the bolts will work and screw in.
I can take measurements of the axles. If the audi axle pattern will work with the Boxster S cv joint pattern, then this will get interesting. There are 6 holes, and the bolts will thread.
It wouldn't surprise me as Porsche and Audi share some parts!
Drudging up an old thread here. Did we ever determine if the audi axle and pattern matches the 986S?
beater986 is offline   Reply With Quote
