Old 12-17-2020, 10:38 AM   #18
blue62
Originally Posted by Jasper7821 View Post
Ya, I should just try it myself and get a bearing press kit and whatever else is needed. It is my 2nd car so not a big deal if it can be driven for a bit. I changed control arm bushings by myself on my old BMW many years ago so maybe I just need to try it.
The Bentley Porsche service manual describes the procedure (with pictures).
IT is pricey around $95.00 but for general service and maint. it is about all that is available. It describes the process and tools well enough that even a novice should be able to do the task.
I suggest that as a first step you purchase the Bentley service manual.
Then you have a means of reference for not only wheel bearing replacement but many other service maint. procedures.
Then after reading,up on an issue (such as wheel bearing replacement) you will have a better idea of if you are capable of doing the job or if you need to hire it out.
The other thing is to be sure it is a wheel bearing you are hearing and not something else. Sucks to spend money and do work and replace parts to find out you didn't fix the problem.
