Old 12-17-2020, 08:31 AM   #16
beater986
UMMMM..... they're are AWESOME.
Pretty tight on the street, honestly, but not the worst street-ride I've ever had. And there's enough adjustment to dial some of that out. but at the track? VERY, very good.
I HIGHLY recommend them. The spring rates were perfect for the way I drive. If I had the adjustment turned-up too high, I would bounce over the bumps in the braking zones, so I'd dial it back just a bit..... perfect. very, very good. As you'd expect Ohlins to be.
What kind of ride height/drop did you experience with these? Trying to stay as close to stock ride height as possible, as that oil pan tray doesn't clear much.
beater986 is offline   Reply With Quote
