I see you are an original owner ... that is always a good thing just knowing exactly what was done to your vehicle and not trying to sort out a used one like mine.
I was looking through threads about upgrades and found the one for updating the Dome/Map light and then I started looking further and found the one in the photo ... it shows for 911 from 1999 up to 2013. It would probably work ... I would have to swap over the infrared sensor so I don't have to have it programmed into the security system and then get the plastic header trim. The frame for the dome/map light is a little wider ... might require a little modification. I might try it down the road a bit. Need to get the vehicle on the road first.
