Rick,
Thanks for this! I did try Becker in the US for this and the message I got back is no longer stocked...do you remember what outfit you bought from?
My plan is a future proof set up. Connect up to this with a terminal block such that one can add additional loads as needed. The block will be powered by the switched 12V and connected to ground lead. The other pins in the mating connector (if I can find it) will be removed or blanked. This will keep the constant 12V lead capped and out of the way.
I will post it here when figure out what terminal block to use.....this is easier than making a harness. The problem is where to mount using screws
986 00S
