Old 12-14-2020, 10:04 AM   #10
Gilles
Originally Posted by Jasper7821 View Post
Found this video, kinda sounds the same. It does sound like it may be a wheel bearing. I guess if it is and turning the wheel would tell me if if it’s in the front right? No sound difference when turning the wheel would mean it’s the rear? I went through the records that are pretty complete from new and don’t see the wheel bearings ever been changed. I see axles removed and new CV boots a few years ago.
https://youtu.be/UpsLaSzcAu4
Jasper, when you turn to the right (a hard long turn IF possible), you will put the load on the left side bearings and you will know if it's a front or a rear one.
Gilles is offline   Reply With Quote
