Old 12-09-2020, 01:41 PM   #7
JFP in PA
I can`t remember now if I just eyeballed it or I measured the 13 mm distance all the way around based on the manual, but this should be doable properly without the tool:
It certainly helps though to have it, I think the tool you are referring to is called 9699.
You need the 9699/2, which has the adaptor for the PTFE seal
JFP in PA is offline   Reply With Quote
