Old 12-09-2020, 08:44 AM   #2
Homeoboxter
One potential issue is that the seal is not seated perfectly. After you pressed the new seal in, make sure it is sitting at the same distance from the crank`s end all around the seal. It`s an obvious thing, so I guess it`s unlikely you didn`t install it properly.
Another thing: the seal originally is not flush with the engine casing, it`s pressed further in by about a mm. I`m not sure if it matters, but may be a good idea to position the lip exactly where it was before.
If all these all checks out, then another possibility is that the crank got scratched during the rebuild. I hope that`s not the case. Once I had to replace the crankshaft on a different car just because the surface of the shaft had some tiny, barely visible scratches right where the seal`s lip ran...
