Originally Posted by particlewave
Jumping the pins only applies to manual tops. Probably a bad idea if your top is still powered. You either have a bad transmission micro switch or one of the top latch switches.
Hey Particle,
Checking things out. Went over the latch switch and it looks ok. I check for a B-pillar switch which my model (2002 Boxster S) doesn't have. Can anyone confirm this? From what I read, this switch sends a signal to the relay that the top is closed. I'm still not sure what the top transmission switch looks like. I did a search and haven't come up with a photo...
