Originally Posted by tonythetiger
most shops won't sew a new window in for a price that makes more sense than replacing the top. Autotopsdirect sells the best tops, Ive compared several and they are FAR superior. You can install the top yourself or find someone competent to do it for you, with the autotops acoustic top. Its nice.
my advice on installation is start at the front with the aluminum bolsters and gluing to the front bow because pulling the new top into the rear channel is much easier and you dont have glue to work around and with. Its easy to get glue on the top during this step and this can be a real mess.
The videos show installing the back first and that makes it harder to get the front pulled, etc.
Another comment is the glass back...at first seems like a good idea, right? If you access the engine to do any work go with the plastic because the top gets completely out of the way. If this isn't a concern, then the glass back is nice except for rear visibility. The glass back is definitely a hurdle if you are back there for things like the AOS, waterpump, cleaning etc.
Thanks for the useful info, I`ll keep these in mind.
