Convertible Top Dash Light
Hi All, 99 Boxster,, I put my hardtop on(1st time) and everything works but the dash Convertible warning light stays lit. I removed the switch and found a bad solder joint so I re-soldered all the joints(8 joints). Same result, all the functions work ie. window drop, I hear the motor run if I press the top down button. Everything was fine with the soft top. Is it just a latch adjustment for the hardtop? I did not plug in the rear defog plug but I don't think that makes a diff. Thanks V****
