Old 12-01-2020, 06:07 AM   #14
djw8282
djw8282's Avatar
Originally Posted by 10/10ths View Post
The OEM engine mounts are the only way to go.
Just think of them as a wear item that your replace regularly.
All of the aftermarket engine mounts that claim to “firm up shifting” et. al., are disastrous.
Even if you get a “slightly” firmer one, they ALL trigger the engine knock sensors and you will actually LOSE horsepower and torque. I have seen it on the dyno.
Just stay away from them all.
Good luck.
Hey 10/10ths,
If a knock sensor is triggered will I get a code? How about semi-solid trans mount with the 987 engine mount?
djw8282 is offline   Reply With Quote
