2000 S 87k $10,000
2000 Boxster S Ocean Blue Metallic
Saddle Full Leather Interior and Metropol Blue Top
ShearComfort Premium, Taylor Made sheepskin seat covers over heated seats
Stock CD player with Infinity Kappa 462.11 in dash, JL audio C1 5.25” in doors
JL Audio RD400/4 channel amp and 8” W3 under dash in custom box
AUX 3.5mm input and USB 1A charging outlet
Other options include:
Traction control
On Board Computer
Ashtray Delete
Very stock 3.2 with 87,000 miles
Great running, owner for last 7 yrs, bought at 53,000 miles and had regular oil changes with Blackstone reports after each- always good results with no increased levels of internal materials or contaminants.
Included with the sale is a Durametric diagnostic tool with only 1 of 3 activations used.
Previous owner replaced clutch, RMS and IMS at 50,000 miles, LN Engineering ceramic bearing.
Recently replaced (with OEM parts):
Water pump
Drivers door lock assembly
Top Center Windshield Microswitch
Front and rear trunk lift supports
Driver Window Regulator
All 4 shock mounts, bump stops and bellows
Bilstein B6 Performance Dampers (not OE)
Brembo cross drilled rotors and OE pads- front and rear
AOS
Iridium
Driver side Oxygen sensor 1
Toyo Proxes tires at 83k
AGM battery
Porsche OE spark plugs and tube o-rings
Body/paint in good shape,
very slight impression in front right quarter panel
Original Metropol Blue top in good shape- Vinyl window was replaced 5 years ago
Up/Down mechanism works properly
Only known issue is a slow leak in Power steering rack. Not sure if it is the rack or one of the lines, but also included in the sale is an OEM rack and tie rods from a salvaged 986 with 28k miles from qualityporscheparts.
Car is located in Charlotte,NC.
Current: 2000 Boxster S....2018 Clubman JCW
Previous: '71 914 2.2 - TX license plate: "E-GO"....'73 914 1.7....'74 914 1.8....'73 914 2.0 - Saturn yellow with all original 2.0 options- R.I.P..... '74 914 1.8 with 916 body kit.... '72 914 1.7 - my very first car
Also: '09 Cooper Clubman....'90 Miata.... '80 MGB.... '76 TR-7
