Old 11-22-2020, 03:46 PM   #1
blue62
Originally Posted by shacky View Post
Been dealing with slight overheating after long idling. Switched relays around with no effect. Turning on A/C and recirculate does not turn on fans. Have witnessed drive side fan come on for a minute at most.
Thinking I need to replace fan ballists and probably fans too.
I see feedback on non Porsche fans that they do not come balanced and have quite a bit of vibration especially in high speed mode,
Any advice is very welcome ��
Have you scanned the OBDII live data to see what temps you are reaching??
Also what temps the fans are triggering at??
Bentley book says:
Low speed kicks on above -206.2 Degrees F or A/C switched on.
High speed kicks on above 215.6 Degrees F .
So if they don't kick on with low speed when you turn on the A/C it could be the ballists
