Old 11-18-2020, 08:03 AM   #10
blue62
Originally Posted by Wolf View Post
What is the spec? is it in then maintenance manual?
The only thing I could find in the Bentley manual was sensor default values.
The ECU goes to a default mode if it detects an open circuit in an AC component or sensor.
That info is on page -87-3 if you have the Bentley manual
The info I used for idle specs. is from my personal notes on research I have done.
I also used my 2000s with a manual transmission as sort of a proof.
I took it for a short drive to get it to operating temp. and it falls in the same range as your car.
My 2000s is in stock tune with 52000 miles and runs excellent.
Idles AC off at 700-750 will go up about 100-150 with AC on.
