Old 11-17-2020, 04:36 PM   #5
blue62
So about the bog you mentioned when coming to a stop with the AC on.
That sounds pretty normal. The engine has extra load on it from the AC compressor.
I will see if I can find an RPM spec. for idle with AC on.
Couple of questions:
Is it a stick or automatic transmission.
What is the RPM at idle with AC off an at operating temp.
If you step on the brake at idle with AC off, does RPM change -vs- not stepping on the brakes.
