Old 11-16-2020, 04:40 PM   #1
MaxD
If you are buying new, get MCS. Will you run Spec Boxster spring rates? They are street-able.
Are you running stagger or square wheels and tires?
You will be fine keeping the M030 bars, but at some point you may want to upgrade to a more adjustable front bar such as the factory 996 GT3 front.
Consider replacing all the top strut mounts front and rear when you do the swap. Go spherical if you don't have to be in a racing class, but the factory ones are not that expensive and will be the latest 997 part.
PCA Intermountain Region Track Chair
SPB #50
MaxD is offline   Reply With Quote
