Old 11-16-2020, 06:27 AM   #1
DoninDel
NewUserName
Battery cables are tight and no corrosion. Car had been starting fine - quick crank and fired right up. Problem first arose when I left ignition turned on with engine off - drained the battery and next time wouldn't start - used the portable battery/air compressor and it started. Next time battery was dead again, I figured I hadn't driven enough, so put battery charger on it, now here I am.
Went through entire curse vocabulary.
Battery is almost exactly 2 years old - I don't drive the car much.
DoninDel is offline   Reply With Quote
