Old 11-13-2020, 05:02 PM   #10
Homeoboxter
Originally Posted by Racer Boy View Post
To properly inspect the bearing, you have to remove it, and that will destroy it.
Yes, extracting the bearing requires a lot of force to free up the snap ring and the bearing is not designed for that, so it`s not a good idea to pull it out and then replace it. But I think it`s sufficient to inspect the bearing in situ in the IMS. I never really understood this proper inspection thing that requires removal. Why would you have to pull the bearing for inspection? Or, what additional advantage would you have if you can hold the bearing in your hand vs if it`s sitting in a tube but you can rotate the inner ring freely? In both cases, all you can check is the extent of free play and the smoothness of running. You won`t be able to inspect the races either way so you won`t have a better idea about the wear just because you pulled it out. If you cut it apart and inspect the races and the balls then you may see some signs of wear, but then the bearing is not reusable because of the extraction...
