Originally Posted by Burg Boxster
My 997 C2S Cab had the CF interior package and sun wreaked havoc on parts wherever they were narrow or w/ complex curves. For instance, the ashtray was replaced 2x under warranty b/c cover edges kept peeling up. Entire center console almost needed replaced but CPO warranty ran out.
The toughest were strips on dash at the a-pillar along defroster vents. Warranty covered 3x. When they peeled up last time I was quoted ~ $450 per side to replace. Um new rear tires or CF on dash - LOL. Tried to get them stay down w some HD contact cement and even Goop but to no avail (similar to I think what your PO tried).
Finally, I just peeled off the entire CF strips and sanded residual glue down to get an even surface on plastic base. Then I bought some "high-def" looking CF wrap in matte finish. Trimmed carefully, applied contact cement to both surfaces and applied. Stayed and nobody was the wiser unless I pointed it out. I had benefit that no other CF parts were within same eye line to see difference but regardless it looked good.
Good luck
What's pretty interesting about my interior is that their is very obvious sun damage, with the clear coat yellowing almost everywhere on the CF, but, no peeling and no de-lamination I can see (yet). I would have expected the same as your interior.
