Old 11-12-2020, 06:45 PM   #241
Qingdao
Qingdao's Avatar
If you are making a custom throttle cable attachment I just did some work to an early 00 Ford Escape. They use the same throttle cable end. Should someone need to make custom bracketry for their throttle cable you can use those drive by cable Ford V6 cables.
I just had to make a bracket for my car (although not a V8). It was JUST long enough to work. However, placement on the edelbrock's throttle had to be moved slightly inbound towards the center of movement. (I don't know how to describe what I did LOL)
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
