Old 11-12-2020, 07:59 AM   #1620
particlewave
Originally Posted by amagalla View Post
Well, if I have to take that stupid thing apart to reattach the lens, I might as well fix the AE at the same time. My real problem now is looking at the factory wiring, all the jacket is peeling away from the wire on the original wiring. I think I'm going to have to rewire the factory plugs. What a pain.
Tony
IIRC, the LED AE ring is epoxied in, as well. It shouldn't be too hard to dig (dremel?) it out, though.
BTW...do you happen to have the "flash to pass" relay diagram?
Tony
The diagrams Paul posted are not quite right...the first one is to turn the AE's off when headlights are on and the second was for a more specific application.
This is the flash to pass relay diagram if you have original halogen high bulbs:
Also, to remove the nut, try some heat. Get a small butane torch and heat the post so you don't damage the reflector bowl. Careful, now...
particlewave is online now   Reply With Quote
