This is all very helpful! Im considering adding Accusump to my 986S for track duty.
Also trying to reduce weight at the same time. Do you have any data to suggest that the 2qt is the best size, or would the 1qt system also cover the vast majority of the needs?
The charts are low enough resolution that I cannot tell if it appears the Accusump is running near the end of its capacity when discharging.
Thanks for any insights you can offer!
