Old 11-05-2020, 07:57 PM   #3
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Laredo View Post
thanks 78f350
If the ABS light is on the scanner could read a code or something?
A faulty switch in the brake pedal goes with a stop brake light malfunction?
In my case it took months for me to figure it out because the brake light still worked. A scanner would have to be capable of reading the ABS module to get a code. Many of the inexpensive ones only read the engine module.
In addition to what Blue62 said about simple tests with a multimeter for the P0134, you can also try swapping the O2 sensors from one side to the other and see if the problem moves.
Are you familiar with the reference of 'bank 1, sensor 1'? That's the most forward O2 sensor on the right side.
