Old 11-05-2020, 07:46 AM   #6
obthomas
ddrucker
I am familiar with molex. That is why I asked the question. As best I can tell Molex does not make a pin as small as the VW pin needed for this connector. I just finished this project and can say that the wires from the stalk need only be about a foot long. Also the stalk can be installed without removing the steering wheel. Turn the steering and remove 2 screws that hold the cap. Turn the steering the other way and remove 2 more screws. Then the side screws each side. Remove the bottom steering cover. Install the 4th stalk and run the wires into and up to the cluster, put the lower steering cover back the same as it came out. Good Luck.
obthomas is online now   Reply With Quote
