Old 11-01-2020, 05:39 AM   #13
Dave80GTSi
Dave80GTSi's Avatar
Originally Posted by jaykay View Post
Found a couple of 99611110105 manifolds. I assume these are the ones you used on your 3.2 heads and fit the circuit werks on the back. Did the standard 3.2 tune work for you. If so where did you put your pre cat O2s? Would it not be too cold back there? I am assuming you extended all four sensor leads to get back to mid pipe cat......
I had ECU Doctors down in Florida do a ROW flash, which eliminated the need for the secondary O2 sensors. Then the remaining pair of primary sensors were fitted to the existing O2 bungs in my Circuit Werks secondary non-cat pipes, using the cable extensions which I've shown above.
Several years later, I've been very pleased with the results - No error codes, and a notable increase in power and rev-ability over stock.
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
Dave80GTSi is offline   Reply With Quote
