Originally Posted by Dave80GTSi
Well, it's been a couple of years now, but as I recall these extensions were something around 18" or so long. I'd obviously recommend that you measure first so to see what length you might need, and then add a couple of inches for slack.
The 'conduit' is nothing more than some high temperature fuel line sleeving, sold readily at such hot rod supply places like Jegs and Summit. Note that I intentionally cut the sleeving to be a few inches longer than the wire itself - thus the 'bunchy' appearance in my pictures.
Several years on now, it's all been working a treat!
Found a couple of 99611110105 manifolds. I assume these are the ones you used on your 3.2 heads and fit the circuit werks on the back. Did the standard 3.2 tune work for you. If so where did you put your pre cat O2s? Would it not be too cold back there? I am assuming you extended all four sensor leads to get back to mid pipe cat......
