Old 10-27-2020, 10:10 PM   #4
bg305
01 Seal Gray 986 S
bg305's Avatar
Very well could be the tank. With that much fluid, hopefully you can see a crack usually I think they're on the bottom unfortunately. I also want to mention just in case there were issues with the early caps see if you have a 01 at the end of the part number on that blue cap in your hand. There's a new version available from pelican with a 04. Worth checking.
bg305 is offline   Reply With Quote
