Old 10-27-2020, 09:30 AM   #3
Ricurb
There is a starter relay in one of the relay panels in the rear trunk.
I would check or replace it with a known good relay first.
They are a very common relay cost 7-10 bucks at most auto parts stores.
As to your clutch switch do you have a grand child or younger person that could assist you? Getting in there even with the seat removed is still tight.
Also removing the seat "can" lead to problems with the airbag "fault warning" if you turn on the ignition with the seat removed.
Blue62-
Thanks good suggestion. I will pull that relay and try that route first. That I can gain access too LOL
Fingers crossed.
Ricurb is offline   Reply With Quote
