Old 10-26-2020, 06:54 PM   #1
Ohtwo986S
Originally Posted by ZDCATC View Post
During your test, was the rear fog light switched on?
Starter986 makes a good point. Our cars' rear fog light only illuminates on the left (road) side of the car. It's possible there's a fog light bulb missing on the right because it never came with one when it was delivered to the US. In countries where the road- or driver's-side of the car is on the right, the fog light bulb is on the right (and presumably no bulb is installed on the left).
If you had the fog light switched off during your test then it could be a faulty brake (or stop light) switch. I'd do a search for that and see if anyone else had similar symptoms.
This first pic is with my ignition on and headlights on. The second pic is with all lights on, inlcuding fogs. Theres no one in the car so the brakes are not lit up, and high beams are off if that matters.
Attachment 22685
Attachment 22686
No the fog light wasn’t switched on. So I took a pic of the light assembly when I went to replace the bulb here:
2670C324-CEB0-4ADD-8D31-FA96BF9805AF
That was the bulb that was missing upon removing the assembly.(this is the right passenger side) As far as I know that’s just the regular tail light bulb. Not for the brakes or fogs.
Edit: D’OH! I realized I was looking at the light assembly wrong. Just switched the bulb to the correct place. I guess because I saw an empty spot I assumed that was where it goes. Tail light now works! Thanks a lot!
Ohtwo986S is offline   Reply With Quote
