Twist the rivet center pins
I broke the first rivet I tried to remove by prying too hard, even using the proper tool. I could get the pin out partially and then it jammed. I found that gripping both the male and female halves with needle nose and/or regular pliers and twisting just the male piece back and forth while pulling worked best. Didn't break any of the others that way.
