Old 10-25-2020, 08:07 AM   #6053
berni29
The O2 sensor socket may flare out and round out the sensor if the sensor is really stuck. Cut the wires and use a deep-well socket or a 7/8" box wrench, if you have room. :
Make sure you turn the engine and ignition off if you cut the wires. Or cut them one at a a time. I cut mine with the engine running (I was trying to keep the exhaust as hot as possible after a blowtorch session) and blew up my DME, or at least the circuit that controls that sensor.
Best of luck
Berni
berni29 is offline   Reply With Quote
