Thread: Front shocks
Old 10-24-2020, 08:51 PM   #3
Vza
I assume you meant the Axle bolt. I torqued to 140 ft lbs then stood on a breaker bar 19 inches out starting from parallel to the ground. I sunk down a ways and seemed about as tight as it was. Tracking it tomorrow will check around if someone has a 400lb torque wrench.
Vza is offline   Reply With Quote
