This is a great write up!
Im considering an Accusump for my 01S that sees a lot of track duty. Wonderful build with the Accusump in the tunnel and the switch on the pressure gauge for oil/Accusump.
One question, I have a journal bearing on my IMS (L&N IMS Solution). There is an adaptor plate on the oil filter joint to feed the IMS bearing. I would assume that I can add the Accusump pick up plate to the IMS adaptor plate. Its a little bit of a Rube Goldburg design, but it should work. Or, can I tap into the Accupump plate for an additional small oil pickup to feed the bearing? Has anyone tried this?
Great thread overall, thx for the morning entertainment.
