Thread: Took a dump
Old 10-23-2020, 01:18 PM   #12
Starter986
1998 Boxster Silver/Red
Filled the trans pan... plugged it... started it up... and this is from where the leak is coming.
After I identified exactly from where the leak is coming I restarted the car for a moment putting it into drive. The wheel spun, in idle. I'm assuming this is a good sign for the TC.
It appears I'll be taking it to an indi, unless someone believes this is a carport-doable job for someone with zero AT experience.
Advice welcomed, thank you.
Name:  zz tran leak.jpg
1998 Porsche Boxster
