Old 10-21-2020, 07:58 AM   #6050
pilot4fn
Last weekend took out the cupholders from between the air vents on teh dash. Same time I installed the AC/heater control unit to the same location and also to the previously AC/heater control location at the very bottom, I installed a storage cubby.
This was pretty fiddly task, since I took some under dash elements away from the wireing re-route. This allowed the wires to be loose enough for the AC/heater control unit to be easy to remove at the later date.
Forgot to take a picture from the starting point but here's the first image from past summer at Kymiring where the original set-up can be seen.
Second image is when the dash was taken in part.
Third image is when all is done :dance:
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
