Old 10-20-2020, 07:20 PM   #10
jaykay
jaykay's Avatar
Originally Posted by Dave80GTSi View Post
Yup!
I tracked down the OEM male and female fittings for each end, such that it then becomes a plug and play deal. Wiring enclosed in that hot-rodder sort of heat jacket, often used by that crowd for fuel or brake lines located close to headers.
If any interest, I can post the Bosch male and female fitting part numbers that you will need to use.
Thanks - DM
Nice Dave. What length did you settle on with which set of mid pipes? What the make of your conduit.....I would think the tricky part is mounting the cable under there and getting the right length
986 00S
