Old 10-19-2020, 04:44 PM   #128
piper6909
piper6909's Avatar
Originally Posted by Twin headlight Ernie View Post
I just changed the oil on my Subaru yesterday. The drain plug has a 17mm hex so I chucked it in my lathe to countersink a 3/8" OD magnet that I got from our local home improvement store. BTW: I like to add a small smear of liquid teflon on the crush washer at the base of the threads.
That's a great idea! I guess the only downside is that it may weaken the plug and it could break? But I seriously doubt it because there should still be plenty of meat left on the plug. Did you use any kind of glue or was it a press fit?
BTW, regarding the crush washers, I re-use the ones on my Subarus all the time. Even the parts manager at the dealer once told me that I can get several uses out of one. I don't know if that necessarily applies to the Porsches, but I've done one oil change on mine and I re-used it without any issue. I'm thinking that such a low torque spec on the LN plug may be the primary cause of all these leaks everyone's having.
2010 Subaru Forester
