Thread: Front shocks
Old 10-19-2020, 01:00 PM   #3
ddruker
If your shocks are original, I would replace them for sure. Also replace the shock mounts, bearing plates and the bump stops - all are wear items. I just installed Bilstein B6's and the ride is much improved.
Shock - Bilstein 22-0465215
Bump Stop - 996-343-301-02
Bearing Plate - 996-343-515-05
Mount - 997-343-018-01
When you remove the shocks, take care to not shear off the clip that holds the break wear sensor wire - it's attached to the bottom rear of the shock. I forgot it was there and destroyed it.
ddruker is offline   Reply With Quote
