Old 10-17-2020, 12:40 PM   #1
Qingdao
Qingdao's Avatar
Not sure if that helps you any way, but on my car this connector is blank, wasn`t used and capped off. The only cable that comes from the tranny is the reverse gear switch. Perhaps it`s optional and the speed signal for the speedometer is coming from the ABS sensors?
I guess you guys are right. Its not like me to just toss out a connector; especially not one that came off the trans.
Shriek it will, soon enough.
I got all the coolant things sorted. I have the coolant temp sender in the heads. I don't know what kinda temps thats gonna read; I might move it to the intake manifold as thats the OE location on the Chevy truck.
Looks like I'm just held up by a clutch slave cylinder. Then I just have to re-assemble the exhaust, drop the car off the jack stands, and wire it up.
'98 PP13B powered "RX986"
