Old 10-05-2020, 11:45 PM   #90
WizardSmokey
Shapeshifting Lizard-Man
WizardSmokey's Avatar
Decided the radiator mounted on the cage wasn't getting good enough airflow, so it's been relocated. Also tied the OEM radiators into it, so the coolant now goes back through the big one, then all the way forward into the two OEM radiators, then back to the engine. Installed a small booster pump to make sure it flows all the way. Pretty sure it won't overheat as quickly now.
WizardSmokey is offline   Reply With Quote
