Old 10-03-2020, 01:26 PM   #10
Homeoboxter
Originally Posted by McSpooney View Post
Thanks Homeoboxster. It's reassuring to hear from someone that has had hands-on experience with this job.
I went all-in on pulling the head with the motor in the car. Tappets and tappet cradle are out. Nothing is impossible so far, but maybe wasted an hour or so that I shouldn't have because I've had trouble getting tools into places or seeing what I was doing. I've also wasted a ton of time because the service manual is so confusing to understand and it just isn't a simple process. I've pulled heads off of other cars, done maybe a dozen timing belts/chains. This one is really something.
Also waited a few days to get the 987 timing tools. Oh yeah. I have a 2003, so my experience may vary from others as the camshafts timing is different (its a 3 chain motor w/ 987 heads).
Still have to do the actual deed of pulling the head off. Will do that tomorrow.
Looks extremely painful To be fair, my junkyard experience was on a 986 and only on the left side. Also, I didn`t have to put anything back on so I wasn`t too careful with the tools and methods I used to pull the parts... You may have to lower the engine a bit and play with a jack movig it up and down to be able to pull out all the head bolts. Good luck!
