Old 10-02-2020, 10:33 PM   #166
pilot4fn
Thanks for the tip, but the mount insert on this car was made of steel. So was the replacement. Steel insert in an aluminum housing. I can`t see how it`s possible to cut the insert out easily without damaging the aluminum bore. Scroll back, only the core part of the mount is aluminum, then rubber, then steel. And the steel shell is pressed into the aluminum housing. Maybe there are different versions?
I had same dilemma last year. Purchased the engine mount bushing only and attempted to change it to the aluminium housing... plenty of fight on this stage and I finally ended up ordering a new housing with new bushing installed. I stil have the ole housing and the separate bushing waiting for next round
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
