Old 09-24-2020, 03:45 PM   #13
blue62
Originally Posted by mgfranz View Post
On the 986, the battery will drain in less than two weeks if not hooked up to a trickle charger. When the battery drains, I have found that more often than not a cell will fail and the battery needs to be replaced.
So either get a trickle charger, or drive it at least every other day.
Then you have some parasitic draw on the battery.
For the battery to drain in less than two weeks is not normal.
