Old 09-23-2020, 02:46 PM   #12
Coaster
Coaster's Avatar
Correct, and Porsche went back to the rivets in 2005. 03/04 with no rivets is a bad idea. I put caulking under my 03/04 tail to keep the cover on. Still there after a year and several 100mph+ testing
Bumping an old thread. went to open my trunk and found the spoiler cap loose. Three of the 4 clips had failed. Age I suppose. Any suggestions for the caulk? Any long term considerations for using caulk? Like, will it be impossible to remove later? Or, does it impede access to anything else I might want to get to later?
New unpainted ones appear to run $150 to $180. If some silicon caulk does the trick might stick it back on - at least for a bit.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is online now   Reply With Quote
