Old 09-22-2020, 06:59 AM   #7
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by flouese View Post
Nothing? No suggestions on where to start?
Many of us have been through this, not that hard.
first, you need to look at it. The top is pretty simple, a couple of rods connect the clamshell and the frame. They need to be disconnected so you can articulate the top and check for cables, rod ends and transmission. Try this, be careful not to scratch up your paint!
https://www.revolution-porsche.co.uk/faq/convertible-roof-stuck-working-can-closeopen-manually/
after that, convert to manual or repair the broken bits. motor is in the center with cables going to each side to transmissions for left and right. Transmissions are behind the foam "gutter" Plug up the drains so any small parts dont fall and get clogged. The cables break and one half rises, breaking the ends off of rods. The transmission gears break and top wont move. It is usually one side or the other, so report back and tell us what you find.
